It is currently Fri Aug 08, 2025 5:34 am
PostPosted: Tue May 26, 2009 10:11 am
What viscocity should I use in my 1979 gearbox please?
Is SAE10-40 the way to go?
many thanks
PostPosted: Tue May 26, 2009 10:44 am
I use Honda HP4 10W-40 in all of my Honda motors, vintage and modern.
It provides more than enough shock protection, works well for the
clutch and is relatively inexpensive. What more can you ask for?
PostPosted: Tue May 26, 2009 3:48 pm
You can go with the engine oil suggestion or straight SAE 80 weight gear oil. I have used both Bel-Ray and Maxima. It is far more important to change it regularly than fret over the brand.
PostPosted: Sat May 30, 2009 3:40 am
Ruairi
jim from sydney here,just rebuilt my 73 250 gearbox with the help off a ex mx star from the 70 here in aus and he is also a exerlent motorcycle mechanic and still a shit hot rider in vmx.he told me to use stuff like castrol 4t.the modern gearbox oils are for the modern bikes which get the clutch faned more time in a rase meet than the vmxs get in a year.in my cz i use almost diff oil as there is now wet clutch.
ps
how is your yz400 going.and is there a new web page for antig as the old 1 is goone
cheers
jim
Jim Garvey
1x honda cr250m 1973 in bits
1x yetman triumph dirttracker
PostPosted: Sat May 30, 2009 3:43 am
Castrol 4T with Trizone Technology is a modern engine oil designed specifically for 4-stroke engines to ensure good all-round protection for your bike’s three critical zones, the engine, clutch and gearbox. Exceeds all current industry 4T standards.
Benefits
The engine is protected against wear and deposits
The clutch is protected against slippage and grab
The gearbox is protected against pitting and wear
Applications
Suitable for use in all Modern Japanese and European Bikes.
Performance Levels
Castrol 4T provides the following performance:
API Service API SE
JASO (T903) JASO MA
Viscosity Grades SAE 20w40
Jim Garvey
Users browsing this forum: Google [Bot] and 33 guests
