It is currently Fri Jul 04, 2025 5:01 pm
 Post subject: 76 MR175 - HELP!
PostPosted: Fri May 28, 2004 3:54 pm
I am experiencing a problem with my 175 - I have cleaned my tank - lines - filters - plugs & condenser... checked all my electrical connections & my bike has no upper RPM (breaks up -) and as it warms up it just winds down & barely runs. Starts just fine.
Bad Coil?
 Post subject: MR175
PostPosted: Fri May 28, 2004 4:52 pm
Check your exhaust pipe to see if it is plugged. I had the same problem with one of my MR's. Take the baffle out an run a coat hanger wire thorugh the three holes inside the pipe and see if it gets any better.
