what weight of oil? https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=258 |
Author: | Guest [ Thu May 27, 2004 7:08 pm ] |
Post subject: | what weight of oil? |
i have a 78 cr250 and i was wondering what is the proper weight of oil to use when doing an oil change? just a 5w30 or? thanks! |
Author: | Guest [ Thu May 27, 2004 7:11 pm ] |
Post subject: | |
sorry also what is the correct amount to put back in..... thanks |
Author: | redrocket190 [ Fri May 28, 2004 1:55 pm ] |
Post subject: | |
If you just drain the transmission in place, put 500 cc back in. If you are doing a re-build put 750 cc in. There is a cross-head/hex oil level screw on the right-hand side of the motor , but I do not use this method to check there is enough oil in the transmission. I use motorcycle-specific Bel-Ray SAE80 weight oil rather than automotive products to avoid any friction modifiers that will hurt performance of the clutch. |
