It is currently Tue Aug 12, 2025 9:47 pm
 Post subject: MR vs CR timing
PostPosted: Sun Feb 21, 2010 6:36 am
Need help with timing a motor I recently bought. 74 cr250,I think it has a MR crank in it. I cant rotate the Stator far enough to get my 1.5mm. point gap at .016. I notice my other CR Motor has a female end on the crank and this one has a male end.
Jim
217 652 2217
 Post subject: Re: MR vs CR timing
PostPosted: Mon Feb 22, 2010 2:12 pm
The ends of the crankshafts I've seen look the same. But if you've got a MR crank in a '73-'74 engine, it is likely your piston is going to hit the cylinder head unless someone put a shorter rod on it. Can't answer your timing question, but on the MR, you can't make much, or any change to your timing other than the gap in the points.
Users browsing this forum: Bing [Bot], Google [Bot] and 32 guests
