MR vs CR timing https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=2600 |
Author: | gooch1010 [ Sun Feb 21, 2010 6:36 am ] |
Post subject: | MR vs CR timing |
Need help with timing a motor I recently bought. 74 cr250,I think it has a MR crank in it. I cant rotate the Stator far enough to get my 1.5mm. point gap at .016. I notice my other CR Motor has a female end on the crank and this one has a male end. Thanks Jim 217 652 2217 |
Author: | mitchie [ Mon Feb 22, 2010 2:12 pm ] |
Post subject: | Re: MR vs CR timing |
The ends of the crankshafts I've seen look the same. But if you've got a MR crank in a '73-'74 engine, it is likely your piston is going to hit the cylinder head unless someone put a shorter rod on it. Can't answer your timing question, but on the MR, you can't make much, or any change to your timing other than the gap in the points. |
