79 CR250 reeds https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=2603 |
Author: | Dos Rios [ Sun Feb 28, 2010 10:04 am ] |
Post subject: | 79 CR250 reeds |
Anyone running a V force reed valve in the 79 CR250? What year of valve do you use. I believe I read a post on here that the 87 valve will work without modifications. Thanks Terry |
Author: | redrocket190 [ Sun Feb 28, 2010 10:42 am ] |
Post subject: | Re: 79 CR250 reeds |
You are correct. |
Author: | b-joe [ Sun Feb 28, 2010 4:57 pm ] |
you can use all reed valves from 78-01. some yerars have 6 blades, some only 4. i think you can use the v-force cause it fits into 480cc cylinders and 480 reeds are the same as 250´s. |
Author: | Dos Rios [ Mon Mar 01, 2010 9:28 am ] |
Thanks, I just ordered a set of the V force 3 reed valves. Terry 48f |
Author: | montywa [ Thu Mar 04, 2010 9:53 pm ] |
would a boysen rad valve from those same years work as well? Allowing for an intake replacement at the same time |
Author: | b-joe [ Sun Mar 07, 2010 5:56 am ] |
montywa wrote: would a boysen rad valve from those same years work as well? Allowing for an intake replacement at the same time you will have problems with the carb. boot, it´s angled to the right side. |
Author: | Dos Rios [ Mon Mar 08, 2010 2:03 pm ] |
I was told that there's a spacer that I could run with the V force set up move the carb, back a little and it would help the bottom end power. Does anyone have more info. on this? Is it still avail.? T |
Author: | woosh [ Tue Mar 09, 2010 10:58 am ] |
I have seen what you speak of the guy also sells a reed setup for the cr250m. The spacer he sells is supposed to increase torque but I have no idea if it does I also dont remember who it was sorry. |
Author: | montywa [ Tue Mar 09, 2010 11:15 pm ] |
most likely you could use a TRX250R spacer, they are dime a dozen and im pretty sure they share the same bolt pattern as a CR. Lots of different lengths out there from 1/4" to 1/2". |
Author: | redrocket190 [ Wed Mar 10, 2010 9:04 am ] |
Moose Racing sells them. |
Author: | Dos Rios [ Thu Mar 11, 2010 12:31 pm ] |
Have anyone tried one? What thickness did you use? Thanks Terry |
