It is currently Sun Aug 17, 2025 11:13 pm
 Post subject: mr175 problems
PostPosted: Fri May 28, 2004 11:31 pm
I own a 1977 mr175. I need a starter pinion and a pawl, but nobody seams to have it. Is there another engine type that I could snag one off? Maby a mr125? Failling that is there another engine type that can fit in the frame without too much modification.
PostPosted: Sat May 29, 2004 10:22 am
A CR125 uses the same setup. I have quite a bit of misc MR175 stuff, let me look around, I may have what you need. Snap a picture and send it over to me, just to make sure we are talking about the same thing. (mailto:dnyquist@reidtool.com)
PostPosted: Mon Jun 07, 2004 5:30 pm
I am still haveing a hard time finding the parts that I need. How hard would it be to drop a diffrent engine into the frame? Everything else on the bike is fine and I just want to get back to rideing while its still summer. Would a CR125 fit? Or howbout a bigger engine...
 Post subject: MR175 Problems
PostPosted: Mon Jun 07, 2004 7:50 pm
A CR125 engine will bolt right up, but it uses a different ignition system. What parts do you need for your MR other than the kick start pinion and gear?
PostPosted: Wed Jun 16, 2004 12:23 pm
I need a new intake manifold and rear wheel berrings but thats about it. The bike is in exelent condition but I can't start it without those kick starter parts. man this is getting annoying. all I can find is wanted ads for the parts that I need.
Users browsing this forum: Google [Bot] and 14 guests
