It is currently Fri Jun 20, 2025 5:44 pm
 Post subject: Jetting 80 CR 250
PostPosted: Sun Apr 25, 2010 10:26 am
Old Question Im sure running stock Kehien at 1400 ' Stock jetting seems to be for around 3000. Any tips Needle is one down from the top Have installed a 55 slow jet and the stock 185 main air screw 1 to 2 1/2 depending on the day.With the 55 it sounds better in Garage and the plug looked as if it was improving. awaiting track test . My manal says if overall rich to drop the floats 2 mm .Any experiences doing this? My fear would be starvation and this bike rips on top. Anybody have needles for these carbs?
 Post subject: Re: Jetting 80 CR 250
PostPosted: Sun Apr 25, 2010 12:14 pm
These are the only needles I'm aware of:
http://cgi.ebay.com/ebaymotors/NOS-Hond ... ccessories
The '79 and '80 carbs use the same slides and the needle jets look identical, so I assume this needle will work. I bought one of these from this guy, and he sent me a 31A needle (16201-430-00) along with the correct 31C needle listed (16203-430-000); no needle jet, just the needles.
I've had bad luck trying to tune carbs using the float height; nowadays I set it once and leave it. In my opinion, the best way to make small adjustments to the overall mixture is with the pilot jet.
