It is currently Fri Jun 20, 2025 2:55 am
Post new topic Reply to topic  [ 15 posts ]
 Post subject: 78 CR250 crank rod kit?
PostPosted: Sat Jun 21, 2008 6:44 pm
Hey guys, I'm new to the forum and would appreciate some direction. Where would I find a crank rod kit for a '78 CR250. Thanks.
PostPosted: Sat Jun 21, 2008 7:53 pm
Contact Racers' Toy Store (where I've been twice) or Crank Works and they'll find an IMS kit to fit.
PostPosted: Sun Jun 22, 2008 6:26 am
as i know is the rod kit from 78 to 01 the same.
PostPosted: Sun Jun 22, 2008 11:19 am
If my memory is correct the 1978-1980 CR250 share the same crank - or least the rod - with an early 80's ATC250R. And there is an IMS kit for the that.
PostPosted: Thu Aug 28, 2008 12:39 pm
Vintage elsinores has them. Thats where I got my kit for my 1980 cr250. Its a Hotrod p/n. When you look up that part number on the Hotrods website it says for later models but it works. Someone got the calipers out and did some measuring.
PostPosted: Fri Aug 29, 2008 11:51 am
Honda, I believe, only sold the complete crank for the bikes. The rod, however, is the same as for the 1981-84 ATC250r. There are aftermarket rod kits for that. I bought two Vesrah kits off of Ebay, and Wiseco sells them as well. The rods definitely are not the same all Cr250 years through 2001. The 78-80 Cr250r rod is listed 64.4mm, the years after are listed at 72mm, with a different kit even then listed for 2002 on..
PostPosted: Mon May 03, 2010 6:30 am
Ok Fellas...
Who is right?
Some say the rod kit from 78 to 01 the same.
FTE sez the rod is the same as for the 1981-84 ATC250r.
Who is right?
Anybody have part #'s from Hot Rods, Vesrah, IMS, Pro-X ect?
My "new" Elsie needs a rebuild.
Stan
WV
83 CR250
83 CR480
87 YZ250
88 CR250
74 TY250
07 YZ250
83 RM250 on the resto table
91 YZ250 with an Ohlins 360 kit in resto que
83 CR125 in resto que
PostPosted: Tue May 04, 2010 11:19 am
The measurement you are talking about is stroke, not rod length. Re-Mx has them for $109. This company shows 78-2001 the same. http://www.motoxparts.co.nz/motoxspares.php?price_image=1&category=0&brand=102&page=1&piece=1097
PostPosted: Tue May 04, 2010 11:51 am
Detailed specs just to be sure http://www.mitaka.co.uk/HONDA%20RODS/CT.78CR250.htm
PostPosted: Tue May 04, 2010 3:45 pm
2 months ago i had a 78-80 crank to rebuild.
send it to my shop here in germany.
they installed a pro-x kit for 78-01.
the orig. crankpin 78-80 is 58mm long, later models uses a 60mm crankpin.
they shortend the pin for these 2mm and installed the kit.
that´s the secret. :D
PostPosted: Wed May 05, 2010 10:53 am
I stand corrected! :oops:
So a current oem kit will work with small mods, eh?
PostPosted: Fri May 07, 2010 8:56 pm
Wish some one would tell me what to do.... LOL
83 CR250
83 CR480
87 YZ250
88 CR250
74 TY250
07 YZ250
PostPosted: Sat May 08, 2010 10:18 am
do it like me.
PostPosted: Sun May 09, 2010 7:50 pm
Did you call Racers' Toy Store as suggested in the 2nd post?
PostPosted: Thu Jun 03, 2010 11:27 pm
Sent my Crank & cylinder to "The Racers Toy Store". Seem to be nice folks.
After looking around for rod kits for this bike, I realized I had 2 kits for my 83 Cr250. An OEM & a Hot Rods. I send both with the crank.
Will report back once I have reconditioned parts in hand.
Thanks Michael for the heads up on the "Store"!
Stan
WV
83 CR250
83 CR480
87 YZ250
88 CR250
74 TY250
07 YZ250
