1976 mr 250 running problems https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=2761 |
Author: | daredevil [ Sun Jul 25, 2010 12:19 pm ] |
Post subject: | 1976 mr 250 running problems |
I have a 1976 Honda mr 250 elsinore. i was riding it and it lost power when i shifted to third gear. it began to run incorrectly with slow throttle response. it will still run but it runs incorrectly. now it will not pull off now. any suggestions |
Author: | badsix [ Mon Jul 26, 2010 6:19 am ] |
Post subject: | Re: 1976 mr 250 running problems |
try a new spark plug then clean and blow out the carb. check to make sure fuel is coming from the tank, remove tank filt and clean, clean tank, clean air filter. check to make sure exhust is all clear, check all electrics. these are just normal maitance things that should be done ![]() |
Author: | daredevil [ Mon Jul 26, 2010 9:08 am ] |
thanks i will try that tonight its to hot to work during the day ![]() |
Author: | aja72 [ Mon Aug 09, 2010 1:52 am ] |
Change the spark plug and also change the engine oil. And Before you ride check gear box once. |
Author: | daredevil [ Thu Sep 16, 2010 4:52 pm ] |
ok thanks |
