MT 250 engine racing with choke off https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=2787 |
Author: | rayivers [ Fri Sep 03, 2010 6:15 am ] |
Post subject: | Re: MT 250 engine racing with choke off |
Adam, Try doing a search here for 'mt250 carb idle' - I got 134 results. I would also turn your idle speed screw (on the left) way out so that the motor idles at a reasonable speed with the choke off. If turning the screw has no effect, you may have a throttle-cable problem. Ray |
Author: | b-joe [ Fri Sep 03, 2010 3:48 pm ] |
download the shopmanual at www.honda-elsinore.com it may help you. |
Author: | reddrt [ Sat Sep 04, 2010 4:47 pm ] |
Would a cracked carb insulator cause the motor to rev like this? PS: Located the shop manual. Thanks! |
Author: | mitchie [ Sat Sep 04, 2010 7:30 pm ] |
Absolutely. Whenever you get a racing engine, one of the first things to look for is an air leak, which leans the mixture. |
