38mm carb on 89 cr125
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=2797
Author:  ecky89 [ Wed Sep 08, 2010 6:03 am ]
Post subject:  38mm carb on 89 cr125
Has anyone got experience or knowledge of fitting a 1989 cr250 38mm carb on a 1989 cr125? particularly settings jetting etc, does it work? is it a big improvement?
ecky89
Author:  mitchie [ Mon Sep 13, 2010 6:09 am ]
Post subject:  Re: 38mm carb on 89 cr125
Never done it. And anything CAN be done, but question remains, should it? Typically, when you go to larger carb on small-bore engines, you gain some top end, but lose some low end grunt.
