It is currently Fri Aug 15, 2025 12:42 pm
PostPosted: Tue Oct 12, 2010 6:06 pm
So I made an error tonight when I removed the triple clamp from the 1980 CR80...I did not realize the steering stem bearings were loose bearings and when I loosened the top nut and lifted the top clamp of the tree all the bearings fell out and rolled all over the floor of my shop....so my question is can I replace the loose bearings with a race style bearing? ANy suggestions would be great--IF NOT, anybody know the bearing ball size to replace the missing ones? Thanks--Doug
PostPosted: Wed Oct 13, 2010 3:23 pm
i replaced my worn bearings with this set.
http://cgi.ebay.co.uk/Honda-CR80-CR-80-1980-1983-Steering-Head-Bearings-Kit-/290474651749?pt=UK_Motorcycle_Parts&hash=item43a1a37065
but you can also go with one of the balls to a bearing shop to get new ones. then i would replace all because they are not expensive.
PostPosted: Wed Oct 13, 2010 8:19 pm
Yes--saw those on ebay last night--just wondered if they worked and fit well or not--looks like I have to drive out the old carrier that is seated in thstem itself anf replace with the oncluded one that comes with the brearings? Thx --DOUG
PostPosted: Thu Oct 14, 2010 1:14 pm
yes, you have to replace all the old bearing parts with the new ones.
