It is currently Fri Aug 15, 2025 7:42 pm
 Post subject: cr450r pistons
PostPosted: Mon Oct 11, 2010 11:35 pm
can anyone tell me what the wrist pin diameter for a 1981 cr450r and also the compression height of the pin bore in the piston trying to see if the yamaha yz 465 {85mm} piston will work as these{cr450r} are about impossible to find or maybe someone knows what will work thanks
 Post subject: Re: cr450r pistons
PostPosted: Tue Oct 12, 2010 12:06 pm
wrist pin diameter 20mm
compression height 40,5mm
