It is currently Fri Aug 15, 2025 2:12 pm
 Post subject: dented tank
PostPosted: Sun Oct 17, 2010 7:31 am
Is there any way to get dents out of an aluminum tank? if not what kind of filler (bondo)do you guys reccomend thanks, Craig :D
 Post subject: Re: dented tank
PostPosted: Mon Oct 18, 2010 12:30 pm
a really good metalsmith can work miracles. But it sometimes entails cutting bottom off tank and rewelding it. And it is unbelievably expensive. Good luck. I've never tried bondo or any other filler on aluminum, but I've seen aircraft guys use standard microballoon auto filler on small dents. They etch the aluminum first.
PostPosted: Sat Oct 23, 2010 10:54 pm
i wouldnt fill it if its a huge dent. but its also expensive if you redo the whole thing. upwards of a grand for complete restore. depends on how much you want it to be perfect. have heard a lot of home made remedies (air pressure, fuel and lighter) but they usually have really bad results unless you REALLY know what youre doing. recommendation...live with it, or take it to a pro. its really hard with these small tanks
PostPosted: Sun Oct 24, 2010 9:31 am
could you post some pictures of the tank :)
