where can i find a 1980 CR250 Rod kit https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=2856 |
Author: | montywa [ Thu Nov 04, 2010 11:54 pm ] |
Post subject: | where can i find a 1980 CR250 Rod kit |
Race season is over and its time for a rebuild. I searched a bit and i had trouble finding a rod kit for the red rocket. Although one company in england was selling the same rod for 78-01 cr250. None of the other companies sell the same rod for the same years?? ANy help would be appreciated. Thanks |
Author: | b-joe [ Fri Nov 05, 2010 10:00 am ] |
Post subject: | Re: where can i find a 1980 CR250 Rod kit |
you can use all rodkits you can get for cr250 till 01. they all have a crankpin that´s 60mm long but for 78-80 models you need a 58mm pin. your rebuilder has to shorten it about these 2mm. |
Author: | montywa [ Sat Nov 06, 2010 9:27 am ] |
that pin is very hard i think, i have access to a full machine shop but i wonder if it could be shortened in a lathe? |
Author: | b-joe [ Sat Nov 06, 2010 2:44 pm ] |
this pin is hardned to 58-62 HRC. it can be machined with a CBN tool. |
Author: | redrocket190 [ Tue Nov 09, 2010 1:27 pm ] |
http://www.racerstoystore.com/. Did two of my engines and dropped in an IMS Hot Rod kit from a later Honda. |
Author: | montywa [ Wed Nov 10, 2010 1:52 pm ] |
Well i ordered a newer rod kit, and a guy i race with is an expert machinist for a production shop. We were talking about how to shorten a pin that hard without marking the pin. He says he can put in on a magnetic table, and precision surface grind the 2mm off it no sweat. I am going to press apart one of my spare cranks and measure first then match it with the new pin. SHould be good to go!! Thanks for all the help guys. |
Author: | montywa [ Wed Nov 10, 2010 1:53 pm ] |
redrocket190 wrote: http://www.racerstoystore.com/. Did two of my engines and dropped in an IMS Hot Rod kit from a later Honda. Just to clarify, they didnt modify the pin at all? As in all that i just mentioned is a waste of time most likely? |
Author: | redrocket190 [ Tue Nov 16, 2010 10:41 pm ] |
Must have been a don't ask, don't tell thing. |
