79 cr250 bearing
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=2904
Author:  crcraig [ Wed Dec 15, 2010 7:40 pm ]
Post subject:  79 cr250 bearing
anyone know how to remove the clutch lifter shaft bearing on 79 cr250 I need to remove for blasting and powder coat thanks, Craig
Author:  b-joe [ Thu Dec 16, 2010 10:01 am ]
Post subject:  Re: 79 cr250 bearing
i tig-weld an allenscrew whitch head fits into the bearing to it.
than heat the case and pull at the screw.
or your next motorcycle shop may help you, they have special tools for pulling sutch bearings.
Author:  crcraig [ Fri Dec 17, 2010 6:03 am ]
I guess I will bring it to my local shop to be pulled the bearing is NA is there another source to get one
Author:  b-joe [ Fri Dec 17, 2010 12:11 pm ]
it´s a standart bearing,
HK1612
id 16mm od 22mm h 12mm
the small seal is also std. 16x22x3mm
