83 forks>79 wheel https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=2913 |
Author: | crcraig [ Sun Dec 26, 2010 8:25 am ] |
Post subject: | 83 forks>79 wheel |
will my stock 79 cr250 wheel work with 480 forks, I read that triple clamps need stem pressed out from 79 then into 480 triple is this right? thanks and merry christmas everyone, Craig |
Author: | sodaworks [ Sun Dec 26, 2010 10:02 pm ] |
Post subject: | Re: 83 forks>79 wheel |
Craig, Yes on the stem but you'll need to run a 83 CR480 wheel. Your 79 will bolt up using the 83 axle but it will be offset to the righthand side by 1/2". Found this out the hard way. Terry |
Author: | redrocket190 [ Mon Dec 27, 2010 10:56 pm ] |
Did you try the the 1979 axle? I remember someone running the older front wheel with the newer forks at CalVMX some years back... It is not required to transfer the steerer (although I did). You can use a spacer - a very large washer - under the top triple clamp to make up for the longer steerer. |
Author: | crcraig [ Wed Dec 29, 2010 2:26 pm ] |
the 480 forks are an after thought on my 79cr250 resto I still have not gotten them yet and was looking to see what is involved in this swap I was hoping to use stock 250 wheel as the hub has allready been powdercoated also the triple clamps I guess they can be sold on e-bay or something I do plan on racing this occasinaly and that the suspension is 1 of this bikes weak points I was hoping that someone knew for sure that the 250 wheel will or will not work, these restos get expensive fast and I still need to rebuild top and bottom of my regular race bike (yz450f) thanks everybody for your input and happy new year ![]() |
Author: | redrocket190 [ Thu Dec 30, 2010 9:00 am ] |
Well if you stick with the stock forks, there's a mod for the damping I posted over in the Reference section of the site. Also I have a Simons after-market kit for the stock forks too. |
Author: | crcraig [ Fri Dec 31, 2010 2:18 pm ] |
I looked for damping mod still have not found it yet,the simons kit is that similar to a race tech emulator valve ? if you are selling this send me pm or e-mail thanks, Craig |
Author: | redrocket190 [ Sat Jan 01, 2011 12:33 pm ] |
If you have the stock 37mm Showa forks and want to make them more supple, consider this. Drill a hole with a #54 bit exactly two inches up from the base of the damping rod - the opposite of the end that screws into the fork cap. When put back together run 275 cc 5-weight fork oil. This is a recommendation from Al Baker "back in the day"... |
Author: | montywa [ Tue Jan 04, 2011 9:07 am ] |
i swap back and forth on my 80' with the stock wheel and the 82 cr480 wheel. Ive never noticed the offset durring a race. |
Author: | crcraig [ Wed Jan 05, 2011 5:47 pm ] |
do you use the 250 axle? does the brake stop on the 250 fit into the 480 forks? or do you change the brake hub |
Author: | montywa [ Thu Jan 06, 2011 12:28 am ] |
i swap the complete wheel and brake back and forth. The lug on the 480 forks works fine with the 80' 250 brake hub, the cables dont swap though, i leave the cable on the wheel when i take it off. I use the 480 axle for both wheels as well |
