Repairing a crack in the engine case on a 74 CR250
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=296
Author:  eprovenzano [ Mon Jun 28, 2004 9:01 am ]
Post subject:  Repairing a crack in the engine case on a 74 CR250
I'm working on my 74 CR250. I've have an air leak which I've traced to a crack in the engine case. The crack in the case was caused when a rock or something must have become wedged between the front chain sprocket and the engine. (At least that's my best guess) The case has a slight crack near the clutch post.
My question, has anyone tried to weld the case on this engine. I do have access to a alum welder, and I'm planning on giving that a try, but wanted some input as to any other options. It not a large crack, I could use JB weld, or other product, but If it can be welded, I would prefer to go that route.
thanks for the help.
Author:  Rick [ Mon Jun 28, 2004 10:57 pm ]
I sold one of these back in '75 after I threw a chain through the case. My neighbor bought it and used JB weld. Held great so if you have to do it, just clean it really good first. As for welding, I don't know if it is alum or pot metal.
Author:  karmak [ Tue Jun 29, 2004 11:19 pm ]
Post subject:  cr 250 case
The cases on these bikes are magnesium. They can be welded by someone who knows how to weld the stuff. I broke off the small part that holds the clutch cable on the right side case on my mr. A welder friend of mine t.i.g welded a lump of weld on the case. Then i ground it back to shape.
Author:  Guest [ Wed Jun 30, 2004 9:21 am ]
The cases are aluminum, and the side covers are magnesium on the 250M's, get your local weld shop to put a bead of aluminum were the crack is and grind it smooth to shape.
