1983 CR250 water pump case
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=2976
Author:  sobodos [ Sun Mar 27, 2011 4:00 pm ]
Post subject:  1983 CR250 water pump case
I have read in some posts that the aluminum clutch cover from a 1981 cr250 will work on the 83 cr250 and I would like to know if someone has first hand knowledge that it fits. I see that the gasket for the 81/82 clutch case is the same but the 1983 clutch case gasket is a different number.
David.
Author:  b-joe [ Mon Mar 28, 2011 11:09 am ]
Post subject:  Re: 1983 CR250 water pump case
yes, cause at 83 they added one bolt, rest is the same.
here a 82 cover.
