'78 CR250 and '81 ATC 250R engine similarities? https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=3006 |
Author: | dorkpunch [ Thu May 05, 2011 11:41 pm ] |
Post subject: | '78 CR250 and '81 ATC 250R engine similarities? |
Curious mainly about the flywheel / electrics... I'd like to "dual sport" my CR and make it street legal. In Idaho, that means a headlight and tail light. I've got a motor from an '81 ATC 250R along with the complete wiring harness. Will the flywheel / stator fit in the CR? Also just kind of curious, how similar are the rest of the engine- piston / top end, transmission internals? The cases are WAY different, the ATC has a counterbalance sticking way out the front... |
Author: | woosh [ Thu May 05, 2011 11:46 pm ] |
Post subject: | Re: '78 CR250 and '81 ATC 250R engine similarities? |
Hey Dorkpunch havnt seen you on a board in ages. |
Author: | dorkpunch [ Fri May 06, 2011 7:13 am ] |
You just havent been to any of the right boards. ![]() |
Author: | b-joe [ Fri May 06, 2011 4:53 pm ] |
dorkpunch wrote: Will the flywheel / stator fit in the CR? no. and the cylinder and head are different in porting and style, so that the ATC has ~10hp less. piston and rod are the same. check the parts catalog here: http://www.hondapartshouse.com/honda-parts.aspx?aribrand=HOM |
