82 honda cr 250 crankshaft collar https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=3034 |
Author: | jedi61 [ Wed Jun 08, 2011 12:26 am ] |
Post subject: | 82 honda cr 250 crankshaft collar |
On the water pump side of the crankshaft there is a metal collar that goes on the crankshaft and turns in the crank seal. Is their an o ring that goes behind this collar to prevent leakage between the collar and the crankshaft? The honda service manual does not show any o ring behind the collar and the honda dealer could not help. The Clymer repair manual says to replace the o ring with every rebuild, if this is the case; where can I get this o ring. Thank you for your help. |
Author: | davep [ Wed Jun 08, 2011 8:37 am ] |
Post subject: | Re: 82 honda cr 250 crankshaft collar |
i have a 82 and a 81 bilt both engines there is no o ring there is a tapered end that seals |
