Fox Air Shox on 78/79 CR250
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=304
Author:  J [ Sun Jul 04, 2004 4:47 pm ]
Post subject:  Fox Air Shox on 78/79 CR250
Is anybody running Fox Air Shox on their 78/79 CR250?
The Fox Shox from my 79 CR125 won't fit the 250 unless I notch the upper mount a small amount with a cutting wheel. Is this what you have to do?
J
Author:  Mike505 [ Sun Jul 04, 2004 6:55 pm ]
J,
I had a 78 CR250 with Fox airs and the upper mount for the shocks had to me notched just as you have said. This will allow the top shock mount to slide in. I have a spare 78 CR250 frame and I think it has been modified also. I will take some measurements and let you know.
Mike
Author:  Mike505 [ Sun Jul 04, 2004 7:02 pm ]
J,
Unfortunately, the spare frame I have is a stock CR250 and has not been modified. I don't recall exactly how much material was cut away, but I am sure someone out there in the vintage world does?
Mike
Author:  redrocket190 [ Mon Jul 05, 2004 10:33 am ]
I ran 17.5" Fox Airs on CR250R 1978 and 1979 frames without the need to notch the upper mount. However they were black bodied ones which I believe are earlier than the silver gray ones. What color are yours?
The lower mounts on the stock swing arm do have to be notched (for most shocks). I have only found one arm so far that has not been modified. After-market arms like my DG are already built to take non-stock shocks and have lower profile mounts.
Author:  J [ Mon Jul 05, 2004 12:20 pm ]
Michael,
They are silver/gray and I will be using the stock swingarm until I can find an aluminum one. So I guess I better let the sparks fly. LOL
J
Author:  Nathan [ Tue Jul 06, 2004 12:05 pm ]
I've been running 17.5" Fox Airs on my 79 CR250R for the past two years. They are the silver/gray bodied models and I have had no problem with them. Once when the thottle stuck wide open up a hill, I got launched from a height equivalent to a 2 story building and landed at the bottom of the hill on flat ground. :shock: As I was floating through the air I knew I was going home in the meat wagon. Those babies sucked it up and I didn't even crash. From then on I was sold on Fox Airs!
Author:  Mike MacMillan [ Fri Jul 09, 2004 10:38 am ]
Post subject:  Fox Airs on a '79 CR250
I'm using grey bodied Fox Airs built in 1979 on my 1979 CR250. They fit in the lower mounts (stock 1980 swingarm) with no conflict. However, on the left side, the top of the shock body barely touches the frame strut heading down toward the foot peg. This is an old time clearance problem with an easy fix.
Put the shock in the top mount and mark the contact point with a sharpe. Remove the shock. Take a round rachet extension bar and lay it across the contact point, and smack it with a hammer. The roundness of the extension bar will make a small indent in the frame for clearance. Don't overdo it. All you need is a trace of daylight between the shock and frame. The mod isn't noticable, and doesn't hurt the integrity of the frame.
