Greetings,
My '79 CR 125 is running fairly well now, but there's a few things that concern me:
First of all, the cluth doesn't lift properly. I rebuilt the tranny, and when doing so inspected the clutch basket for grooves that would bind the plates. I ended up putting a different one in from the three parts engines I have that's in great shape. I compared the length of the lifter shaft and thickness of the lifter plate to the others and Clymer manual, and they all were the same (needed a caliper to tell a difference, and it was vvvery slight). My bike won't idle while in gear unless I rev it. When not running and in gear, there is a pretty decent amount of clutch drag when I push it. I've adjusted the cable to its stops, and can't seem to remedy it. Anything else that might be causing it?
On the tuning, it runs well but has a fair amount of exhaust smoke. The flange on the cylinder leaks out huge amounts of black exhaust goo. By the end of a 15 minute ride, the downtube and fender are covered in it. I know its leaking past the pipe, as I installed new gaskets and observed it while running and don't see a leak past the gasket, just out of the pipe. Is there any type of RTV or anything that could seal up the gap between the pipe and the exhaust flange? Even with the leak, should it be producing this much messy black exhaust residue? I don't have a lot of experience with two strokes, so don't know how much smoke/exhaust is normal. I've also thought about putting a stiffer spring from the pipe to the flange to hopefully help keep it more rigid and sealed.
Thanks for your help, this forum is great.
-Pat-
