75 cr125 carb help https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=3070 |
Author: | Geo38 [ Sun Aug 07, 2011 7:21 pm ] |
Post subject: | 75 cr125 carb help |
Ordered a 32mm flat slide for my 75 cr125 a few months ago.Go to finally install and it's roughly 1/2 in short on the back throat of the carb.My question is have any of you tried a flat slide? Or is the 30mm round the prefered way to go.Also the drain bolt on the bottom of the flat slide is maybe a 1/16 off the engine case.(real tight) Hoping C.P.W. will help me out with another carb. What do you guys recommend? The reason i got the flat slide was because at the time 30mm rounds were back ordered and was told by C.P.W. this would be a better set up and would make the bike run better. My motor has a mild port job,NOS stock crank and rod installed,webco head and DG pipe.Not that modified but enough to help it. Any thoughts,recommendations appreciated. Thanks |
