To convert or not to convert... https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=3113 |
Author: | Texas77 [ Wed Oct 05, 2011 12:29 pm ] |
Post subject: | To convert or not to convert... |
how hard is it to convert a mt250 to a CR or mr 250? What is a mr in relation to the other two? ![]() |
Author: | JonW [ Wed Oct 05, 2011 7:20 pm ] |
Post subject: | Re: To convert or not to convert... |
Different bikes... so not easy and why bother?! but yes, you can run the engines in other frames, but the MR is more like the 75/76 CR and the MT is more like a 73/74 CR from my memory... |
Author: | ~JM~ [ Thu Oct 06, 2011 1:29 pm ] |
There is performance to be gained by swapping a CR250 top end onto the MT250 lower. I don't think the MR will swap. You will need the 1973-74 cylinder, head,piston, intake, carb & exhaust. All of these parts are highly desireable for Vintage MX racers so none are usually inexpensive. ~JM~ |
Author: | nola_fiddy [ Tue Oct 11, 2011 9:32 pm ] |
If you're just tinkering around and don't have some special project in mind, Don't Convert: Unless you have a problem with the existing bike and you can't get replacements for the right price or at all. If you want a CR, it will be cheaper and better to get a CR. If it's a unique project you want, then go for it! My vote would be to go the OEM (or clone) route. Probably cheaper and easier to sell if the day comes. nola_fiddy 1979 cr125r |
