"80 CR80R Choke assembly https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=3201 |
Author: | 56mulberry [ Sun Nov 27, 2011 1:19 pm ] |
Post subject: | "80 CR80R Choke assembly |
Looking for a 1980 CR80R choke assembly ("enrichener valve..")...I am sure other same era Honda carbs had/have same part.... last part needed to finish my restoration (other than side plastics and airbox cover...) Anybody got one to sell in good shape? If so please email me at: alexcitychiro@bellsouth.net Thanks Doug Roberts |
Author: | 56mulberry [ Sun Nov 27, 2011 1:29 pm ] |
Post subject: | Re: '80 CR80R Choke assembly |
Same part also called "Starter Valve" used on these models....if it helps: here is Honda part number: 16046-169-004 1980-81 CR80R, 1981 CR250R, 1981 CR450R thanks again--DOUG |
Author: | 56mulberry [ Thu Dec 22, 2011 9:35 am ] |
Post subject: | Re: "80 CR80R Choke assembly |
ANybody got one? Still looking for a choke assembly/"starter valve".... thanks DOUG |
Author: | crcraig [ Thu Dec 22, 2011 12:28 pm ] |
try E-bay search ( keihin pe choke ) there are several listed I am not sure on the cr80 carb size but it seems the choke assy. is the same for numerous carbs might also want to check out www.sudco.com , Craig |
Author: | 56mulberry [ Sat Dec 31, 2011 10:31 am ] |
I placed a bid on one of them-- just cant tell for sure if they are actually a direct fitment or not-- I know the manual shows the same OEM PN for 80-81 CR80, 81 CR250 and 450.... WIll have to research some more on the carb size.....thanks DOUG Its all I lack to run the bike too! |
