forks
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=357
Author:  RobbieHorner1 [ Thu Sep 02, 2004 7:55 pm ]
Post subject:  forks
I have two questions
- how much fork oil do i need for a 1979 cr250 for each fork?
- what size for seal driver do i need for the same bike.?
Author:  J [ Thu Sep 02, 2004 10:56 pm ]
RedRocket190 answered the first one some time back.
"If you just pump the old oil out of the forks; 205 cc. If you are completely re-building them; 275 cc. Weight is SAE 5-weight."
I'm not sure about the seal driver.
J
Author:  redrocket190 [ Fri Sep 03, 2004 2:08 pm ]
If I remember correctly the fork tubes are 39mm in diameter so get a seal driver of that diameter. But really you can just warm the fork leg with a blowtorch and then tap the seal in with a large socket of the right size. Beware the dust seal that fits above the actual oil seal is a discontinued part so if you change the seals make sure you get that part out un-damaged.
