all cr250 78-01 have the same bolt pattern to screw the reedblock to the cylinder so they all fit to the 79 rocket.
the orign. reedblock has 6 blades, later 4 blade blocks let a bit more air in. don´t know if you really remember it at top end, i don´t.
cheapest way to improove the orign. is to put dual stage reeds on it.
the radvalve will fit into your cylinder but the boot is angled by side.
another intresting reedblock is the tassnari V-Force.
spacers are made to get a smoother down end but loose a little bit at top end. it downs the precompression in the crankcase.
