78-80 CR250 ingnition swap
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=3718
Author:  GSjimmy [ Tue May 22, 2012 7:56 am ]
Post subject:  78-80 CR250 ingnition swap
OK, I need some advise. I have traced the running problem I have with my 1980 CR250 and have determined that the ignition is at fault. So, I'm going to ditch the 1980 ignition and install an earlier unit.
What I need to know is if I will need a letter coded flywheel to match the "A" code stator. Will the 1980 flywheel run this ignition? Working on finding a good "A" code CDI box as well.
Also, is there anyone that "rebuilds" CDI's or stator coils? I know it's a long shot, but I had to ask.
Jim
