It is currently Sat Aug 16, 2025 11:04 pm
PostPosted: Fri Aug 10, 2012 2:54 pm
Hey all,
Busted my muffler exhaust bracket the last night and had to ride home sputtering (different issue) with my foot holding it in place.
Does anyone here know where I can get a replacement? Ebay has one but it's worth more than the bike!
Thanks.
PostPosted: Mon Aug 13, 2012 10:39 am
Which bracket is broken?
If it's the rear one on the shock bolt, the MR175 unit will work if the small top tab near the shock bolt is bent flat or ground off. It's actually a heavier-duty bracket than the OEM MT250 one. I put one on my friend's MT a few months back, it worked fine.
http://www.ebay.com/itm/HONDA-MR175-MR- ... 5c&vxp=mtr
If it's the center rubber bracket, this place may have something that will work if you can't find the OEM one:
http://www.vibrationmounts.com/Products1.htm
Something similar to the V10Z2M305DM06 may work for you.
Users browsing this forum: No registered users and 7 guests
