redrocket190 wrote:
1978, 1979 and 1980 forks will fit the stock 1979 triple clamps because they are the same size fork tube. 1978 - 1987 (at least) triple clamps use a common headset bearings and therefore will fit your 1979 frame. The steering tube will be longer and will require a large washer under the top triple clamp. Or you need to have someone with a press transplant your 1979 steerer to the newer lower clamp. 1981 Showa forks are 41mm and as rare as the CR250R/CR450R from that year. 1982 forks are 43mm 3-way adjustable. 1983 forks are Showa and 15 click adjustable. 1984 on the forks went to a disk brake design and need fabrication to use with the 1979 drum brake. With 43mm forks you can use the newer double-leading shoe hub (and its correct axle) or use the 1979 hub and axle.
I am running 1983 Showa 43mm forks with Racetech springs and Emulators in a 1982/1983? 43mm triple clamp set with a 1979 steerer. I run a 1983 front hub.
Sweet, now the question is: If I find a 82-83 CR250 triple clamp, then the 83 43mm forks along with a 83 wheel and brake faceplate, will the bars be moved back an inch or so? I know this is a problem with the CR480 triple clamp
Kristi
