It is currently Sun Aug 17, 2025 1:37 pm
PostPosted: Tue Jun 29, 2004 8:45 pm
A resent post suggested replacing trans oil with Automatic trans fluid to help reestablish their seal.
Is this true?
If so, how long should it be left in?
PostPosted: Wed Jun 30, 2004 8:42 am
I would imagine that ATF has some additive to keep seals soft/pliable, but I not sure that would bring a bad seal back to workable condition. There are some "Snake Oil" type products at auto parts stores that may or may not work. It may need to be run in the trans for awhile and I'm not sure that would be a good thing for a manual trans. (?) Any transmission experts out there?
J
#829 The "Factory Novice"
1988 Honda CR250RJ
1983 Honda CR480
1981 Can-Am 250 MX6-B
1979 Honda CR250RZ
1979 Kawasaki KX250 A5
1978 Husky 250CR
1978 Honda CR250R
1977 Yamaha YZ400D
1977 Suzuki RM125B
 Post subject: ATF
PostPosted: Sat Oct 09, 2004 5:29 pm
ATF makes seals swell but it's only a "slight" thing. If you have a bad main seal that is sucking oil - it's probably too late. Usually the ATF fix was reserved for a fork that was barely weaping or something like that.
Good luck - let us know if it works. BTW, you need to find a "Suzuki" guy that has a 1989-92 to tell you which ATF to use - as one works well with our clutchs and one type burns them up.
Just run a Yahoo search for RM250 ATF and see what comes up.
Peace...
Mikeee P
The Race Isn't Over Until YOU Cross The Finish Line!
