Slack in counter sprocket, any ideas? https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=3825 |
Author: | oleguy [ Mon Oct 08, 2012 6:59 pm ] |
Post subject: | Slack in counter sprocket, any ideas? |
Seem to have alot of wiggle in my counter sprocket after install, sprocket looks fine, probably alot of wear on the shaft. I really dont want to split the case and replace the shaft at this point, unless my crank seals are bad. Anyone ever delt with this? |
Author: | intermx [ Wed Oct 17, 2012 1:21 pm ] |
Post subject: | Re: Slack in counter sprocket, any ideas? |
Honda drive sprockets, the ones with the two screws and retaining ring, are designed to move a bit. Unless your shaft splines are very worn, this is not a problem. dean (Honda mechanic in the 70's) |
Author: | oleguy [ Wed Oct 17, 2012 7:09 pm ] |
Thanks alot for the reply |
Author: | dogger315 [ Sat Oct 20, 2012 1:09 pm ] |
Quote: Honda drive sprockets... are designed to move a bit. But not too much. I ran into the same problem when restoring my 73 CR250. The first test fit with a good, but used CS sprocket produced quite a bit of slop. I found a NOS CS sprocket and that reduced the slop a little. Then I found a NOS countershaft and now it's a nice tight fit with no movement. IMO, the culprit here is the countershaft itself and the two bolt design. The two bolt design allows a rider to keep using a worn out CS sprocket which, in turn, eventually wears out the countershaft due to the poor strength of the alloy Honda used though out the transmission. I recommend you purchase a repro or NOS CS sprocket and put it away in case you're ever lucky enough to find a NOS countershaft. In the mean time, that little bit of slop will get bigger and bigger every time you put the bike in gear and experience that driveline snatch. dogger |
Author: | oleguy [ Sat Oct 20, 2012 8:38 pm ] |
thanks alot for the info! |
