Ray, do you think it's better to use the pump or blank it off?
For me, it would depend on the particular MT250. Quite a few have had the entire oil injection system removed, and in that case it's sensible to go the premix route after blanking off the pump mounting hole if not already done.
I consider the oil injection to be a cool feature of the MT, so if the bike was complete / in good shape and the injection appeared to have been in constant use since day one, I'd keep it intact, no question. If all the parts were there but it looked like the system had been disconnected or tampered with, I'd probably replace the pump and whatever else I thought was needed to get the oil injection up and running again, provided I could find the parts. From what I've seen the system has a tendency to put out too much oil and proper adjustment is important, even if it means settting it differently from Honda specs.
