1979 CR250R Clutch questions https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=3910 |
Author: | Leemata [ Sat Dec 22, 2012 2:47 pm ] |
Post subject: | 1979 CR250R Clutch questions |
How does the "Clutch Lifter" come out of the right case? I need to remove it to send out to be replated. I removed the phillips head screw below it, but it doesn't want to come out. Do I need to remove the clutch and the "Lifter Rod" first? Will the small needle bearing stay in place if I remove the lifter? Terry |
Author: | Leemata [ Sun Dec 23, 2012 8:25 am ] |
Post subject: | Re: 1979 CR250R Clutch questions |
Figured it out by removing the lifter rod and the lifter arm pulled out easily. The needle bearing is apparently pressed in the center case. Terry |
