It is currently Fri Aug 15, 2025 9:27 am
 Post subject: Vintage Honda Paints
PostPosted: Thu Feb 07, 2013 9:21 am
Hello everyone out there! Just wanted to let you know I have developed some CR paint colors. After much research, I was able to come up with original paint formulas. It is a single stage appropriate for frames. I sell it in pint forms, which is easily enough to do multiple frames, swing arms, etc. The paint can also be used for tanks but you must wait a couple of weeks before installing decals and clear coat. This is so that the gases will dissipate from the paint. I sell these on ebay under the seller name 2manyvintagebikes. Colors that I have matched exactly are Tahitian Red, Flash Red, Fighting Red and Monza. I ship these without reducer and hardener, as these are available at your local paint store. They are shipped with a tech sheet so you know exactly how to use and type of components you need to mix. For the complete set up you will most likely spend under $100. This is far better than the over $200 price tags some of these guys are charging. Most of us are on a budget and that is a pretty heavy hit for the limited amount of paint we would use. Naturally you will need to know how to use an automotive sprayer but this paint has much more solids in it than your typical rattle can, which usually UV's or washes off after a period of time. Hope this helps. Linda
 Post subject: Re: Vintage Honda Paints
PostPosted: Fri Feb 08, 2013 7:15 am
WOW...That's $520 a gallon! :shock:
