It is currently Thu Jun 19, 2025 6:35 am
 Post subject: connecting rod bearings
PostPosted: Tue Apr 09, 2013 12:22 pm
All right, i finally got time to work on the 74 mt 125. Originally i thought hole in piston, but it turned out top ring was gone.
I took the piston off and inspected piston pin, bearing. pin shows wear so i assume the bearing has wear also.
according to my manual it says to replace with matching bearing to the connecting rod. my rod has 3 marks indicating a white color coded bearing. but it gives no measurement for the bearing.
the manual has 3 different connecting rod marks , so 3 different bearing color codes.
the parts manual only shows 2 different bearings. one being a .... Never mind, i mis read the bearings in the parts manual. i see i need the .004-.006
i could of deleted this entire post and saved myself the embarrassment, figured ya'll needed a laugh. now back to the regularly scheduled program
Users browsing this forum: Majestic-12 [Bot] and 23 guests
