connecting rod bearings https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=4018 |
Author: | OkieRob [ Tue Apr 09, 2013 12:22 pm ] |
Post subject: | connecting rod bearings |
All right, i finally got time to work on the 74 mt 125. Originally i thought hole in piston, but it turned out top ring was gone. I took the piston off and inspected piston pin, bearing. pin shows wear so i assume the bearing has wear also. according to my manual it says to replace with matching bearing to the connecting rod. my rod has 3 marks indicating a white color coded bearing. but it gives no measurement for the bearing. the manual has 3 different connecting rod marks , so 3 different bearing color codes. the parts manual only shows 2 different bearings. one being a .... Never mind, i mis read the bearings in the parts manual. i see i need the .004-.006 i could of deleted this entire post and saved myself the embarrassment, figured ya'll needed a laugh. now back to the regularly scheduled program |
