It is currently Fri Jul 04, 2025 10:05 pm
PostPosted: Thu May 05, 2005 5:20 pm
does any one know where they sell transmission rebuild kits,, or individual parts, i have a 1974 MT250 elsinore,, today i was going up my driveway hard in first then i shifted into 2nd,, and the engine just revved freely,, when i stopped and looked, the countershaft was spinning, and the sprocket wasnt..uh oh.... ,, i took the side cover off,, and took the sprocket off and where theres supposed to be metal (keyways/slots), what ever you call them
there was none except for the very front of the shaft, which isnt being toushed by anything............. :( help would be much appreciated!
~ jeff
If you want big rewards, take big risks.
'74 MT250E
workin gettin another
definitely an addiction
PostPosted: Fri May 06, 2005 9:49 am
Jeff,
Try Western Hills Honda http://www.westernhillshonda.com or look on Ebay. There are some vintage Honda parts still available new from any Honda dealer though I suspect most tranny parts are no longer in stock.
Good luck,
Loren
Loren Davis
51y
 Post subject: hey loren, thanks
PostPosted: Fri May 06, 2005 10:25 am
hey loren, thanks ill check that out, ill go to westernhillshonda, ive checked ebay, and yes, i will call my local honda dealers.... thank you very much, any help is VERY much appreciated ~ jeff
'74 MT250E
PostPosted: Fri May 06, 2005 1:34 pm
Western Hills Honda is very good for finding discontinued parts. However if they don't have something you are looking for try http://www.cmsnl.com. The prices are in Euros so be sitting down, and you will need the part #.
 Post subject: mt250
PostPosted: Fri May 06, 2005 9:40 pm
I have some used MT250 trannies. You need the output shaft at the very least. You will need to split the cases so I would do the seals and bearings while I had it apart. Email is mailto:elsinorestuff@qwest.net
