It is currently Wed Jul 16, 2025 10:02 pm
PostPosted: Fri Jul 05, 2013 4:52 am
The case for the headlight on the MT250 is held on with bolts running through a nut on the inside of the case on each side. Each of those nuts has a wire with bullet connector soldered to it. What are those wires for? Doesn't seem like it makes sense to have them as grounds since there is a chassis ground wire that comes into the light housing as well.
PostPosted: Sat Jul 06, 2013 5:09 am
it´s the ground for the turn signal lights mounted to the headlight.
PostPosted: Sat Jul 06, 2013 7:24 pm
That makes sense. Thanks.
