It is currently Fri Jun 20, 2025 5:56 pm
 Post subject: cr250 -82 clutch
PostPosted: Sun Jun 09, 2013 12:32 pm
Hi.
I need new friction plates and springs for my clutch.
Can I use these parts from an -83 cr250?
Regards Mikael
KX250F -09, CR250R -82
 Post subject: Re: cr250 -82 clutch
PostPosted: Mon Jun 10, 2013 12:08 am
http://www.barnettclutches.com/products ... tch_cc=250
Bad news: 1982 and 1983 appear to be different. Good news: Barnett makes parts for both.
PostPosted: Mon Jun 10, 2013 12:45 pm
Ok, thanks redrocket.
Got another question, the big sprocket that is riveted on the clutch basket is a little loose. Should it be that way?
/Mikael
PostPosted: Wed Jun 12, 2013 10:54 am
is it loose to the basket or basket and sprocket to the shaft?
clutch springs
don“t kow the barnett springs but often aftermarket springs are stiffer than the originals and this is not necessary for the CR.
stiffer springs cause a harder pull at the lever.
try first the original springs and fill in an oil that is made for motorcycles with wet clutches.
there has to be JASO MA printed on the oilcan.
PostPosted: Wed Jun 12, 2013 3:51 pm
Hi.
It is little loose to the basket, I guess the rivets has come loose after all use.
Dont think it should be that way.
Yea I had a feeling that aftermarket springs could be harder.
I would use the original, but one is missing. I will see what I can come up with.
Here is a pic of the rocket taking shape :D
PostPosted: Thu Jun 13, 2013 12:19 pm
MikaelH wrote:
Hi.
yep, basket and sprocket have to be tight together.
Users browsing this forum: Bing [Bot] and 32 guests
