It is currently Thu Jun 19, 2025 1:25 am
 Post subject: 74 mt250 to 74 cr250
PostPosted: Thu Jan 24, 2013 7:56 pm
i have a 74 mt250 with a freshly rebuilt motor, and i was just wondering if they're were any other differences between the mt and the cr in 74 aside from the motor? i know there are some aesthetic differences and have already removed the groovy turn signals and tail light but i would also like to ditch anything that doesn't help go faster, or stop shorter! love the raw look of the old cr's
 Post subject: Re: 74 mt250 to 74 cr250
PostPosted: Wed Jan 30, 2013 5:51 am
I think the frame on the cr250 is lighter. Aluminum vs. steel wheels, different carb, air box, and the motor differences.
PostPosted: Wed Jan 30, 2013 12:54 pm
there are many differences between these two bikes.
it´s like beetle and porsche. :mrgreen:
PostPosted: Fri Feb 01, 2013 6:24 pm
Diggin the vdub reference. Do I need the rectifier?
PostPosted: Fri Feb 01, 2013 6:36 pm
With no lights or battery, you shouldn't need the rectifier at all.
If you're looking to unload the groovy turn signals, I know someone who might be interested in them.
PostPosted: Sat Feb 02, 2013 3:32 pm
I spent a lot making my mt250 like a cr250 and honestly I dont like it. I need to modify the frame because it has terrible head shake under acceleration. I am assuming its from the steering angle but really I dont know for sure. I did make the rear end a tad taller but not the front so I guess moving the shock mounts to lower the rear might work too. I only did this to an mt250 because I wanted a bike that looks like a cr250m but can be used on the street.
PostPosted: Fri Sep 13, 2013 9:35 pm
Hi all, I have a 74 MT that I use for dirt tracking and I was wondering if anyone has dropped a CR motor into an MT, encountered any problems etc?
Thanks in advance.
PostPosted: Sun Sep 15, 2013 12:30 am
the 73-74 CR250 engine will bolt right in providing you get the CR250 air cleaner,CR250 34 mm carb and pipe from the CR or the top end from a 73-74 CR250 will also bolt on to a 74-76 MT250 lower end.to get it to run strong you will need to use the CR250 carb and pipe.
i ran my 1974 MT250 with a 73 CR250 complete engine assembly with a NOS Kehin 34 mm CR250 carb and stock CR250 air filter and a DG 73-74 CR250 pipe on it for a while.it was very quick,setup like that!
putting the 28 mm MT250 carb and stock pipe will choke the hell out of the CR250 engine so i don't reccomend doing it that way.
many CR250 engine parts like the Clutch assembly and straight cut primary gears can be used in the MT250 engine,the transmission gears like using the MT250 1sr and 5th gears will give a low gear for plonking and 5th will give it a eye watering top speed of over 80 mph.
it is really fun to mix and match MT and CR250 parts.
Users browsing this forum: No registered users and 44 guests
