MT250 headlight wiring question https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=4100 |
Author: | safetyfast [ Fri Jul 05, 2013 4:52 am ] |
Post subject: | MT250 headlight wiring question |
The case for the headlight on the MT250 is held on with bolts running through a nut on the inside of the case on each side. Each of those nuts has a wire with bullet connector soldered to it. What are those wires for? Doesn't seem like it makes sense to have them as grounds since there is a chassis ground wire that comes into the light housing as well. |
Author: | b-joe [ Sat Jul 06, 2013 5:09 am ] |
Post subject: | Re: MT250 headlight wiring question |
it´s the ground for the turn signal lights mounted to the headlight. |
Author: | safetyfast [ Sat Jul 06, 2013 7:24 pm ] |
That makes sense. Thanks. |
