It is currently Wed Jun 18, 2025 9:42 pm
PostPosted: Sat Sep 14, 2013 10:27 am
75 mt 250. I can't get the turn signals,brake light,horn,and rear light to work. Head light works with high beam and low beam. Kill button works on handel bar switch. Key switch is disconected. It does not work if its connected or not. Its aftermarket. Anyone know where I can start checking wires?
PostPosted: Sat Sep 14, 2013 8:43 pm
Do you have a good battery? those lights work off the battery. And it should be routed through the ignition switch, you really need a electrical schematic to wire it correctly.
The headlight works off the stator
PostPosted: Thu Oct 03, 2013 12:34 pm
I do have a new battery. I think your right with the ing. switch. I will start there. I do have some wiring diagrams. Thanks for your help.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 34 guests
