mt 250 electrical problem
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=4156
Author:  pkauto [ Sat Sep 14, 2013 10:27 am ]
Post subject:  mt 250 electrical problem
75 mt 250. I can't get the turn signals,brake light,horn,and rear light to work. Head light works with high beam and low beam. Kill button works on handel bar switch. Key switch is disconected. It does not work if its connected or not. Its aftermarket. Anyone know where I can start checking wires?
Author:  OkieRob [ Sat Sep 14, 2013 8:43 pm ]
Post subject:  Re: mt 250 electrical problem
Do you have a good battery? those lights work off the battery. And it should be routed through the ignition switch, you really need a electrical schematic to wire it correctly.
The headlight works off the stator
Author:  pkauto [ Thu Oct 03, 2013 12:34 pm ]
I do have a new battery. I think your right with the ing. switch. I will start there. I do have some wiring diagrams. Thanks for your help.
