Convert atc250r 300 top end kit to 1979 cr250 ????
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=4191
Author:  mxcentral [ Tue Nov 05, 2013 7:48 pm ]
Post subject:  Convert atc250r 300 top end kit to 1979 cr250 ????
Hi guys , Does anyone know if the 300 top end kit for the 250r is anywhere near compatible for a 1979 cr250 ?? If the cylinder bolt pattern is close the rest should be doable. Anyone ever seen the 300 kit for the atc ??
Author:  b-joe [ Sun Nov 10, 2013 5:47 am ]
Post subject:  Re: Convert atc250r 300 top end kit to 1979 cr250 ????
http://www.hondapartshouse.com/oemparts/a/hon/506f8aeaf8700229747b9484/atc300r-kit
this kit was made by mugen as the 360 kit.
i´ve seen a used one on ebay some years ago priced a bit higher than a 360 kit and imidiately sold.
in a 79 frame you will get a problem with the outlet. it´s straight as the 80 cr.
