1978 cr250 choke ? https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=4214 |
Author: | sting66cp [ Mon Dec 30, 2013 5:15 pm ] |
Post subject: | 1978 cr250 choke ? |
I'm trying to locate a replacement choke for the factory Keihin carburetor on a 78 cr250 and I'm not having much luck, I believe the part number is 16046-430-020. Is there another choke that will fit this? Or is this part available anywhere ? Thanks. |
Author: | sting66cp [ Tue Dec 31, 2013 11:47 am ] |
Post subject: | Re: 1978 cr250 choke ? |
sting66cp wrote: I'm trying to locate a replacement choke for the factory Keihin carburetor on a 78 cr250 and I'm not having much luck, I believe the part number is 16046-430-020. Is there another choke that will fit this? Or is this part available anywhere ? Thanks. I'm also considering just installing a new flat slide carburetor for this, and I am looking for some advise. Would you go with a Keihin or Mikuni? and what model number carbs are a direct fit for a 78 cr250? Who has done this, and what was your experience with this mod ? Thanks. |
Author: | stevie_d13 [ Tue Dec 31, 2013 2:17 pm ] |
We run flat slides on all our Rockets. We use later 1986 on-wards CR 250 carbs. We keep the stock jetting to stat with. They are pretty much a "bolt on" mod. We do a tiny bit of machining on the inlet stub so they fit into the inlet manifold a little better, some guys I know don't bother. But I think it helps to get a proper seal. We then use a 90* throttle assy, and a 97 Cr 250 cable. Parts are easy to ge tfor the PJ, unlike the PE carbs. The PJ works really well, inproves throttle response and gives a little bit extra on the top end. Stevie |
Author: | sting66cp [ Tue Dec 31, 2013 3:28 pm ] |
stevie_d13 wrote: We run flat slides on all our Rockets. We use later 1986 on-wards CR 250 carbs. We keep the stock jetting to stat with. They are pretty much a "bolt on" mod. We do a tiny bit of machining on the inlet stub so they fit into the inlet manifold a little better, some guys I know don't bother. But I think it helps to get a proper seal. We then use a 90* throttle assy, and a 97 Cr 250 cable. Parts are easy to ge tfor the PJ, unlike the PE carbs. The PJ works really well, inproves throttle response and gives a little bit extra on the top end. Stevie Thank you for the reply and the update. I'm not sure what you are referring to with the (90 * throttle assy), how is this different from the stock throttle assembly? Thanks. |
