Reed Valve
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=4216
Author:  bollockybill [ Wed Jan 01, 2014 8:25 am ]
Post subject:  Reed Valve
Hi folks,
does anyone have one of these or know where I could get one or any info as to this item or other reed valves?
cheers people
Author:  rayivers [ Wed Jan 01, 2014 11:31 am ]
Post subject:  Re: Reed Valve
That looks like a G.E.M. reed valve to me, but I could be wrong. They pop up on eBay from time to time.
The setup below is way better, and probably way more $$.
http://richstaylordporting.com/intake.html
Author:  bollockybill [ Thu Jan 02, 2014 8:58 am ]
Is this one?
Author:  rayivers [ Thu Jan 02, 2014 9:32 am ]
That looks like a DH reed kit.
If you're installing from scratch, I'm sure you're aware there's a lot of work involved to correctly install this kit (intake passage mods, adding piston-skirt windows, boost port cut, etc.). If you're going to go to all that trouble anyway I'd suggest using a modern reed assembly instead, but that's just my opinion.
On page 2 of the .pdf link below is a DH installation diagram for the Hodaka 125, which gives a general idea of what's required.
http://www.strictlyhodaka.com/v/vspfiles/assets/RV.pdf
Author:  ohiomotoxer [ Thu Jan 09, 2014 12:04 pm ]
Top oneis a GEM (that pic is of my old one actually)
the bottom is a DH.
Don't forget you WILL need to put some holes in the piston for any reed to work.
I have the diagram for a 123 somewhere if you need I will look for it.
