It is currently Fri Aug 15, 2025 12:42 am
 Post subject: CR125 problem
PostPosted: Sat Mar 01, 2014 7:58 am
Hello,
I have a '75 125M that I trying to get running. My Clymer manual sez 25/1 mixture. Is that right? My bike smokes & wont idle. Runs better with choke on? Also, I need float levels. If they are in the manual, I can't find them.
Thanx for any help!
Brat
 Post subject: Re: CR125 problem
PostPosted: Thu Mar 06, 2014 12:15 pm
I like 34-40:1 mixture. If it smokes real bad it may have a bad right side crank seal. It also sounds like you need to clean the carb. The float usually will sit parallel to the carb body when lightly seated.
Users browsing this forum: Google [Bot] and 17 guests
